HIGH IAT's with SLP Cold Air Kit?
My buddy gave me an SLP LID and the cold air kit "ductwork"...
Ever since, it seems my IAT's are a bit higher than without, specifically the ductwork...although it might be my imagination???
Just curious if anyone has had this happen, or heard of it happening?
It really seems to get heat soaked fast, which defeats the purpose of it at the track. My engine runs at 195 or less, and I've seen IAT readings as high as the 140's, on an 80 degree or so day, with very little running time between the pits, and the starting line
Referring to this thing, specifically
What were they before you put the kit on? Anything sucking from the radiator area is going to heatsoak at idle. Some people relocate their IAT sensor specifically because of this and just stick it up by the cowl since you're not really sucking in 140*F temps as soon as you start moving and IAT sensors are slow to change?
So, it looks like at speed, they are the same as they used to be, with just the lid.
Minus the ductwork, it looks like most logs show low 100's to maybe 120 degrees if sitting still for a few minutes.
I literally drive to staging lanes, shut car off, and don't restart until the car in front of me is pulling into the waterbox, so it seems it's getting it's heat from sitting and being "held" in the sheetmetal ducting....sound right?
It appears they actually do take an aggressive amount of timing out as well...I must have just moved the table over to delete any retard at lower IAT's
Of note:
My car WAS a rear mount turbo car, hence the custom OS it has...although it is now a CLSD nitrous combo...I was running OLSD but car seems to run much better (all around) with the closed loop, enabling the STFT's only, so far.
I know this is gonna sound terrible but I made a chrs1313 style ram air out of tin and wrapped it in gorilla mainly to hold my self tappers in haha but after sitting quite a while idling it takes a really long time for iats to come up much above ambient. I’m not sure if it’s because my home made set up hangs down a lot lower than the SLP or if the black gorilla tape actually blocks heat some.
I thought about making an extension for mine.
I have to have a front tag in Maryland, so made a very simple hinged front tag for when it had a turbo, to allow restriction free air into the intercooler....
I imagine with some ductwork it would also easily be used as a REAL Ram Air, since it opens up almost immediately...in fact, only time tag is visible is at less than 5-10 mph, or if stopped.
2nd video shows it really well:
https://www.instagram.com/p/BjQL6O-AFNn/?utm_source=ig_share_sheet&igshid=wx50vwjlkj1h
I feel like the fast toys ram air system is a better option for this reason. It's a plastic material similar to the lid and seems less likely to heat soak like one of the metal systems such as the slp
All I saw was a few different size lids, and a deflector made for Trans Ams?
