Throttle Body Coolant Bypass... Results Inside. - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 09-29-2018, 12:29 AM
bjohn's Avatar
Default Throttle Body Coolant Bypass... Results Inside.
Everybody does this modification citing it cooling IATs which I agreed with 100%. However, I had never seen how effective the modification really is so I set out to measure it's success myself in the best "bro science" way I possibly could.
Here's what I found when I did the throttle body coolant bypass on my 2000 WS6... I took multiple measurements with an infrared thermometer before and after installing a TB bypass kit. I drove the same route on the same day, the same way to measure the changes. A video outlining this is below.
Here is a spreadsheet I put together of the effectiveness of the bypass kits. They all work the same (I'm sure), and in principal should yield similar results. This was done on a 40ish degree day in Minnesota. The "IR TB Temps" were taken with an IR thermometer by averaging two readings. One on the drivers side of the TB, and one on the passengers side.
There was quite a difference considering the throttle body in theory should have continued to get warmer if thermal heat soak was going to make a large impact. I suspect the coolant was largely responsible for the initial temperature climb, and subsequent temperature decline. You be the judge!!!!
We all knew this was a good mod to do, but here is "how good".
bjohn is online now
Old 09-29-2018, 08:14 AM
BTC
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
The pic you posted shows 75.35 on the 24 mile trip after the bypass, but the video said 73.35.
BTC is offline
Old 09-29-2018, 10:15 AM
It appears that doing this had a huge stabilizing effect on temps, which is a GOOD thing!
G Atsma is offline
Old 09-29-2018, 10:57 AM
bjohn's Avatar
You would be correct, there was a discrepancy there! I was actually wrong when I went back and checked my math. I must have totally fat fingered that one haha. I updated the temp chart to reflect the change! Thanks for catching it.
That's what I saw too. There was a dramatic ramp up in temperature with the coolant hoses connected (shocker). Without them it was noticeably cooler (shocker again lol).
The point if it was to try and gauge what effect the coolant hoses really had on the TB temps.
bjohn is online now
Old 09-29-2018, 12:36 PM
Chris Paveglio's Avatar
Thank you for doing a well documented, back to back test under the same conditions. :-)
Chris Paveglio is offline
Old 10-06-2018, 11:08 AM
bjohn's Avatar
Thanks for the feedback! It was ballpark science but I think the point I was trying to convey came across fairly accurately lol. We all knew the throttle body would cool off without coolant running through it, but nobody could quantify how much.
I would be interested to see a before and after of IAT's. Unfortunately, I'm not equipped to do something like that at this time. I'd suspect it's not a massive difference, but maybe a degree or two?.... Hard to say without testing it haha.
QUESTION!!!!
Someone had commented on the YouTube video that another reason the engineers run coolant through the throttle body was to aid in preventing carbon build up. I can't find that information anywhere. Is that a thing or not?... Shouldn't be a problem with an aftermarket lid and the EGR being deleted. But in an OEM setup, is that part of the reasoning?
bjohn is online now
Old 10-06-2018, 11:14 AM
I could see carbon building up if there was actually combustion happening close by (lol), but from EGR? Only the earliest LS engines had that, and not sure how stabilizing the temp of the TB would affect that.
G Atsma is offline
Old 10-06-2018, 10:09 PM
fairly sure the coolant passage is so the throttle body wouldn't freeze up in case the car was ever driven in Antarctica.
smurfing GM.
dreadpirateroberts is offline
Old 10-07-2018, 07:02 AM
99 Black Bird T/A's Avatar
Nice research, thank you for sharing OP.
The coolant was routed to the throttle body to prevent it is in hp or freezing. 200-220 degree coolant isn't going keep the TB hot enough to burn off carbon build up or prevent it. My stock 245,000 mile 02 Z28 is proof of that
99 Black Bird T/A is offline
Old 10-07-2018, 04:01 PM
bjohn's Avatar
I agree with carbon buildup only being near an area of combustion. Not sure what might cause it on a throttle body, but the guy was somewhat adamant about it being a big reason to keep it.
smurfing GM.
That was my understanding too lol. There's what, a zero percent chance of these things being driven below 0*F?.....
Thanks, hope it was somewhat informative haha. I'm sort of relieved that nobody else has heard of the "carbon buildup" aspect of it on here. Couldn't find any information searching for it.
Good on you for racking up 245k miles haha! Some people think that these cars should be parted out if someone drives them a lot.
bjohn is online now
Old 10-07-2018, 04:51 PM
trilkb's Avatar
What cam is in that car? Just curious
trilkb is offline
Old 10-08-2018, 08:10 PM
bjohn's Avatar
It's a Brian Tooley Racing Stage 4 Cam.
bjohn is online now
Old 10-09-2018, 11:25 AM
Nice effort and interesting results!
As noted above, the sole purpose of routing coolant through the throttle body is to improve operational characteristics in cold-weather conditions. Essentially, that's accomplished by keeping fuel atomized for efficient combustion, which also limits emissions at idle and low-speed during closed-loop operation.
I'd be curious to see if the reduction associated with the throttle body bypass had any real effect on full-throttle performance. I'm guessing that airflow passes through the throttle body so quickly at high rpm that it has little time to absorb a significant amount of coolant heat. Has anyone ever back-to-back tested this on a dyno?
Rocky Rotella is offline
Old 10-09-2018, 01:01 PM
BTC
I'm pretty sure someone tested this long ago, and it was good for ~ 6hp under heat soaked conditions, but that may have been on the LT1.
BTC is offline
Old 10-09-2018, 01:49 PM
BTC
This thread has a very small before and after dyno graph. It appears to be for an LT1 and I have no idea how trustworthy it might be.
BTC is offline
Old 10-09-2018, 02:51 PM
Freeze-up is actually most likely to be a problem when it's just above freezing and very humid, like, foggy. Aircraft carbs do it from flying through clouds, which are often about those conditions.
A 2% HP difference seems believable.
RB04Av is offline
Old 10-10-2018, 03:03 PM
infinitebird's Avatar
Good thread, agree there is no reason not to do this mod.
For carbon buildup just take off the TB and clean it once in a while. I do that anyway since there is always some junk around the edge of the blade and in the IAC hole.
infinitebird is offline
Old 10-11-2018, 08:21 PM
bjohn's Avatar
Interesting point. I can see something like that happening if there was a LOT of consistent air flow going through the throttle body for a long period of time. Makes me wonder why it never seems to actually be an issue in passenger vehicles... Especially vehicles that never came with this from the factory.
I agree with you. I'd rather clean it that deal with "possible" contamination on the TB lol
bjohn is online now
Old 10-12-2018, 11:09 PM
Pontiacerator
RevGTO's Avatar
I did it on my 01 T/A and afterward I had a couple of rough running episodes after start up when the car had been parked outside on very cold days.
RevGTO is offline
Old 10-13-2018, 08:18 PM
Because they don't very often fly through clouds at a few thousand feet above the Earth's surface at temps in the low 30s for long periods of time at a stretch... although some do.
Get a bit of that kind of experience and you'll understand better why the factory did what they did. Not saying it's "right", you "shouldn't undo it", or anything of the kind; just, UNDERSTAND what you're doing/undoing, and what the factory's intentions were, and that will help you make an informed decision one way or the other. The factory guys/gals aren't STUPID (much... often...) but the reasons they do things the way they did are not always obvious to the casual observer. Sometimes "max power" isn't the ONLY consideration. Especially at altitude.
RB04Av is offline
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
