New 408 build won't start!!! My car doesn't have the transmission hooked up yet but the engine is in the car and as far as I know all the sensors are hooked up and all the grounds as well. Except the transmission stuff and the maf sensors. But my problem is I don't seem to have power to my fuel injectors or coils... I have pressure in the fuel rails and I checked and it's their. Now when a friend cranks it over the starter spins and turns the crank and stuff but it doesn't even start as if its getting fuel and spark their isn't anything. I checked the spark plugs and no power was in them. What could be wrong could it be because the trans isn't hooked up like a safety switch? If so how do I trick it till the trans is done at the build shop? Or am I missing something else any help would be apprectiated. |
Check all your ground and all other connections |
Originally Posted by G Atsma
(Post 19977925)
I would think so, as long as all engine-related electrical is hooked up. |
(Post 19977933)
Where's the tranny? |
(Post 19977953)
The only way the trans wouldn't let the car start is if the neutral safety switch wasn't sending the signal to the ecm to the starting circuit but since your engine is cranking that shouldn't be the cause. The maf could be the reason. Its supposed to tell the engine how much air is coming in so the ecm knows how much fuel to inject. A scan tool would tell you what the computer is seeing and give you a good direction. Check the cam and crank sensors again. They tell the ecm when to deliver spark and fuel. |
Originally Posted by FixMyJunk101
(Post 19977965)
Your pedal position sensor can also turn off your fuel and ignition system. check it to make sure that circuit is complete. it may need to be relearned. that could be the reason your iac is making noises. |
The neutral safety switch doesn’t prevent the engine from starting, it prevents the starter from starting the engine. The transmission being missing has absolutely nothing to do with PCM’s inability to fire the coils or injectors. Did you connect all of the grounds in the harness to the engine? If you did, I would look at the cam and crank position sensors, the PCM may not know the engine is turning. |
if you have a scan tool or access to one you could check all the sensors very easily.Sometimes the connectors are the problem. loose, corroded or damaged prongs are something to check. Your ecm is shutting off the fuel and spark is my guess. Hope this helps yeah. Remember to not use a test light on anything computer controlled or you might have to refill your ecm with smoke. |
What car is this going in and did it run before with the same PCM? If it’s a swap, is the VATS removed from the OS? |
Originally Posted by s30.hybrid
(Post 19978017)
(Post 19977992)
(Post 19977975)
Originally Posted by 8.Lug
(Post 19977983)
Sorry I reread thru your post and noticed you asked if the pcm needs grounding. Absolutely it does. That's the input for all your sensors. All modules should be functioning. The pcm is your onboard diagnostics. it would set dtc's. Theres a cell phone sized scan tool that available on amazon for about $450 last time I looked at them. It would be better to just borrow one if possible. A scan tool wouldn't do much good if the modules are powered and communicating tho Relearning shouldn't need to be done if its the original modules and sensors. SInce you didn't swap the accelerator pedal it shoiuldnt have to be messed with but If the pedal is at 80% (pedal to the floor) and engine rpm less than 600 it enters a clear flood mode which would prevent the injectors from working. Pretty rare to have happen but you cant rule anything out. Sometimes the engine coolant temp can even cause a engine crank no start symptom. I would make sure your modules are working tho. |
(Post 19978338)
There should be a ground wire at the connector that grounds at the fuse panel. I cant remember off the top of my head what pin it is at the connector. A wiring schematic would be useful. Do you know what reluctor wheel is on your new engine? In 2006 they went from a 24 tooth to a 58 tooth wheel to enhance the crankshaft resolution. If your new engine has a 58 tooth reluctor wheel on the crankshaft the old pcm wont work. Also there is cheaper ob2 readers that will tell you the sensor values. You just cant do tests or activate anything like a scan tool would do. There's a book written by Josh Potak called How to Build and modify GM LS-Series Engines. Look into it if you get a chance. |
| All times are GMT -5. The time now is 07:44 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
