Notices
TSP 1 3/4" Header Fitment
Old 11-28-2018, 10:17 PM
Dano 00TA's Avatar
That setup in the video is really close! Mine was nothing near that bad.
Dano 00TA is offline
Old 11-29-2018, 09:09 AM
Originally Posted by lees02WS6 View Post
My biggest concerns came after seeing the video below, and seeing some images on the forum. The headers in the video are not TSP, but after reading 99Silver6.0's comment I was more concerned. Frankly if I had the clearance issues in the video I'd have sent those headers back. I just started working on it, we'll see how it goes. If there are clearance issues with the collectors, and they are solvable with cut and weld that's what I'll do.
https://youtu.be/GeBefNLYiBM
Please keep us posted on what you find.
Originally Posted by 99Silver6.0 View Post
This thread has a few pictures of what I ran into. Post #22. Again, I tried with my 60k mile mounts, new stock mounts and Prothanes. It was worse with the Prothanes.
https://ls1tech.com/forums/generatio...questions.html
That's clearly not right, looks like it's literally touching the under body. I recently swapped out my Spohn solid mounts for UMI solids/stock pedestals in preparation for a new header set up with flanges. I took a ton of pictures and wanted to start a thread showing the difference in height between the two, maybe I'll just post them in here. My point is though that even with the engine jacked up with Spohn mount the collector/flange wasn't touching the under body. A part of the y-pipe was however which was probably due to the exhaust being built before I installed the Spohn's.
Grifter is offline
Old 11-29-2018, 09:10 AM
From your signature it looks like you have ARH's now, how did they fit?
Grifter is offline
Old 11-29-2018, 09:44 AM
99Silver6.0's Avatar
Yes sir, I do now. The ARH fit perfect! Just for the sake of checking I tried them with the old rubber engine mounts, new rubbers and the polys. Not a problem with any of them. Y pipe doesn’t touch anything. The problem obviously wasn’t my car or the mounts I chose to use!
Good 3/8" clearance with the ARH. This is where the TSP stuff gave me problems.
ORY tucks up awesome.
Little hard to give an accurate idea of gap but its right at like 3/8" maybe a tad over.
99Silver6.0 is offline
Old 11-29-2018, 06:07 PM
Very nice. So glad I didn't end up pulling the trigger on the TSP's during the Black Friday sale. Looks like I'll be saving for some ARH's.
Grifter is offline
Old 11-29-2018, 07:27 PM
I know some folks have had good luck, though. Thats why I was pretty upset that I ran into the problems I did. I tried 2 sets of their 1-3/4 headers and Y pipe too!!! In the end after how long my car was in pieces and how many times I had to send headers back and forth I am not the slightest bit upset at what the ARH system cost me. Buy once cry once!
Old 11-29-2018, 09:49 PM
lees02WS6's Avatar
Here’s another example of the collector being very close to the floor board. This one is a tsp
Originally Posted by pressureprows6 View Post
Here is how easy it is to adapt to long tubes...these are tsp....used the front pieces from the kit that would normally go up to the mid length collectors....little bit of cutting and welding and no extra pieces needed..easy...
lees02WS6 is offline
Old 11-30-2018, 03:27 PM
I've got good clearance with TSP 1 3/4 headers but I'm also still using stock 100K motor mounts.
wannafbody is offline
Old 12-10-2018, 12:35 AM
rbl3's Avatar
Also running TSPs 1 3/4, with plenty of room to run 4” cats. The cats are Pacesetters, also running Speed Engineering True dual kit out the back. Here’s a small pic after LT install.
rbl3 is offline
Old 12-10-2018, 07:11 PM
My tsp 1 7/8 fit perfect, they were easy to install
SLP IROC-Z is offline
Old 12-12-2018, 10:26 PM
I bet something about the car is off. I know that I bought a seat mount for my Miata and it was off by 1/4 inch . The company is reputable and the product fits most cars but for some reason mine was off. Maybe both our cars were built on a Friday afternoon.
Old 12-15-2018, 09:31 PM
  #32
rbl3's Avatar
Here’s another pic with 4” diameter cats.
rbl3 is offline
Old 12-22-2018, 04:34 PM
  #33
lees02WS6's Avatar
Everything fit neatly, no issues with the k-members, ls1 external knock sensors on the LS3 cleared easily, and plenty of space between the collector and floor board. Both the driver's side and passenger headers went in with minimal effort, with the car lifted off the ground 24". I did not remove the steering shaft, oil filter, or loosen the engine mounts. I actually had each header in and out four times while I test fit things.
Old 12-23-2018, 09:37 PM
  #34
Those are TSP's? What are you doing for the ball ends?
Grifter is offline
Old 12-23-2018, 10:47 PM
  #35
lees02WS6's Avatar
Yes those are TSP's. Shortening the collectors, and using two bolt flanges to mount the cats.
Old 01-22-2019, 10:10 AM
  #36
lees02WS6's Avatar
I test fit them with the flanges tacked on, everything looked good so they are now welded up. I got them ceramic coated also
Old 01-24-2019, 11:54 AM
  #37
Those look great! Nice job.
Grifter is offline
Old 04-21-2019, 07:08 PM
  #38
lees02WS6's Avatar
More exhaust ****. I couldn't get them polished as the parts were too big for the tumbler, but silver ceramic
Old 04-21-2019, 08:38 PM
  #39
I like the flanges
Old 04-28-2019, 10:07 AM
  #40
lees02WS6's Avatar
Ground clearance is even a bit better, I went through several iterations on the passenger side to get it tucked up as close as I could without it rattling against the floor. Lowest part of the exhaust before and after
Before
After
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
