How to use TBSS intake on Gen 3 5.3L. - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 01-05-2019, 11:46 PM
Default How to use TBSS intake on Gen 3 5.3L.
I am building a 2004 lm7 and bought a TBSS intake. I am wandering how I am going to make this work. The TBSS intake port is a different size then the gen 3, and I canít order a tbss throttle body because it is a 6 prong connector and mine is an 8 prong. Any advice would help.
Matthew Kane Powell is offline
Old 01-06-2019, 01:09 AM
The TBSS is still a cathedral port and will work on your engine. Not all Gen IV's are rectangular port. The LS2 the manifold came off of is a cathedral port engine. Look at the manifold. Notice the injectors are ABOVE the ports? Now look at the heads. Notice the "peak" at the top of the port? That is the "cathedral" shape it got its name from. The injector shoots the fuel down thru the peak into the port.
G Atsma is online now
Old 01-06-2019, 03:18 AM
My question was more with the throttle bodies. The Gen 3 tb is an 8 prong and the gen 4 is 6 prong. Is there anyway to put a new throttle body on and it work? Also, is there a 90mm throttle body thatís dbw that will work?
Old 01-06-2019, 09:08 AM
eseibel67's Avatar
I have no info on how intake will physically fit with which engine or TB.
On the electrical side, my guess is 6 of your 8 pins can be wired to a 6-pin connector (Standard S-1745). The 2 extra pins are a +5v supply and ground that the 6-pin TB consolidates. There might be a ready made conversion harness available but Im not sure so you might have to DIY. LS2 TB is 90mm and uses same 6-pin connector as TBSS, but again I dont know how it mounts.
eseibel67 is offline
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
