LS1 2006 electrical throtle no acceleration.
Hello,
i have c10 1970 with LS1 2006 engine electrically drive ny wire. Everyday First engine start gives no gas, once i switch off / on the car again accelation works. Sometimes its cuts while driving too.
Is this issue is common on drive by wire? If yes what is the solution ?
I passed by few workshops some they said you need to change the harness and the others says this is common defect on the electrical throttle body.
Wants to avoid buying unnecessary spares like new harness, new acceleration paddle or swap to cable throttle.
