SLP Loudmouth too loud
So my car had an SLP LM1 when I bought it. I have since done TSP long tubes and off road Y pipe and a hot cam. I thought the LM1 was a little too raspy before but now it needs to go. Any suggestions on something with more tone and less obnoxious that I can just switch the resinator out for? Also would consider an entirely new cat-back with the muffler in the original spot.
I run Lt's into 3in ory with 4in. merger and 4in. electric cutout.
My cat back is nice and jammed up stock lol.
With the cutout closed its actually pretty quiet. Then I can crack the cutout open a tit for a little rumble or open it all the way to put it on blast mode.
So maybe a cut after the y and then jam it up good after is something to look into. I love it. I have a very slight exhaust note with it closed while cruising and numbing chaos at wot with it open.
Anyway, I need to order 2 high flow universal 3 in cats from summit and put them in the Y Pipe to make this car sound more tuned and less raspy.
I was also thinking of doing a Tick Cam install with a polluter cam in it. Put a hot Cam in my old car but back then that was the ONLY cam you could get none of the companies were making LS cams back in 1999-2000. So im glad I have a lot of choices these days.
Good luck wtih your exhaust
Jennifur
I bought a flopro twister to put where it is....wish I just went with true duals instead of the LM2 to begin with. When I did long tubes and ORY it was stupid, sounded like a straight piped peice of redneck garbage. The twister helped, but its still garbage to me.
Question to you all, HOW can you identify or tell which Loud Mouth system you have?
I got my car with the headers and loud mouth already installed and I have no idea which one I have. is there a tell tale way to identify a LM1, LM2?
My Y Pipe has no cats and is 3 inch pipes into a single collector down to the split over the rear and out the 2 polished slash cut single 3 inch tips.
Not sure if that description will be able to tell if thats a LM1 or 2 but if there is a way please could someone tell me how to tell which one is which?
Also my LM hangs down WAYYYYYYYYYYYYYYY too low, and scrapes on damn near everything on the road, my driveway and speed bumps.
Have an old BMR drive shaft loop that bolts to the underside so I was going to use that and see if that lifts the exhaust up some and gets it higher under the car. was also going to loosen up all the band clamps, and use a floor jack and lift the exhaust up gently and then tighten the clamps back up and see if that gets it a little higher and tucked up under the car better so It does not scrape everything out there and stop it from constantly squeaking and scratching things on the underside. I am not 100% sure but the headers which I think are hookers are a small part of the problem since they seem to hang down lower than they should so then the Y pipe is now too low because of the header collectors. My old 98 I had a long time ago I had the MAC 3/4 length headers with the MAC Y pipe and a borla cat back and I NEVER had any issues scraping anything, squeaking and scratching and scraping on the ground or on heat shields under the car. So i hope I can get this fixed cause the squeaking drives me MENTAL its just constantly squeaking even at idle its squeaking with the engines vibrations. So something is touching the exhaust somewhere so I need to find that and take care of it somehow. but any suggestions or tips n tricks would be extremely and deeply appreciated.
Thank you all......
Jenni
Thank you all......
Jenni
Thank you all......
Jenni
Thank you all......
Jenni
I would try to see if you can get it to sit in there a little better just by moving it around, but a cut piece of radiator hose can do wonders for padding spots where the exhaust may rub.
If you are still considering changing the exhaust entirely, I put a factory dual dual on mine and it is awesome. It has qtp longtubes, off road y with dual 3" to 4" flowmaster merge. Had single 4” with a dynomax bullet. Was super loud. I feel like it picked up torque too with the factory exhaust. Car has a 234/242 cam.
Rob
Rob
Good to know. I found digging through my old stuff the old BMR drive shaft Loop and Cross Brace so I plan on installing that when I get a moment free and use that brace to hold up the exhaust at least in the middle of the car and maybe use a small floor jack to lift the exhaust up when I loosen up the clamps, and then put some upwards pressure on it, then tighten the clamps back up and see if its rubbing any heat shields and either bend the shields so they dont touch the exhaust or manipulate the hangers to not touch or take your advice and use some pieces of radiator hoses and hose clamps to holdl those pieces in place to stop it from squeaking so bad.
Thank you for the tip, appreciate it very much
Jenni
Thats what I’m running with Texas speed ory. Sounds a lot better. Slp muffler isn’t 3” all the way through like the magnaflow. I went to advance auto and bought a 3.5” to 3” o.d ( I think? Can’t remember) fitting.. I cut the merge end off ( think that was 2.75”) and welded the new piece in place. The 3.5 end fit very snug over the merge which made it nice. This little change made a noticeable difference with rasp and only cost $15. Probably flows a tad better also! I know I should’ve went stainless .
i have the same issue. the car wasnt too bad stock with the loudmouth but after heads and cam the partial throttle is just ridiculous. guessing its due to the y pipe. going to try true duals, dont mind loud just a clean loud.
