Loud rattle/squeak when AC turned on Hey all, i have ave a super loud rattle/squeak that starts whenever I turn the AC on. It increases frequency with engine RPM so I’m sure it’s a pulley or belt (or I suppose it could be the actual AC compressor?, but the AC works fine). Any tips on how to identify the culprit? It’s a PITA to get back to those AC pulleys/belt :) Thanks! |
I would spray behind the ac compressor pulley while it's running with something like bg penetrating oil. Easy to get to. |
Take the belt off and spin each pulley by hand. If you don’t hear anything obvious then the tensioner is likely worn out. |
© 2024 MH Sub I, LLC dba Internet Brands
