Need help : LQ4 6.0 sensor part numbers I have been trying to find a part number list for GM OEM sensors with no luck. 6.0 LQ4 Gen 3 2003 motor Knock oil pressure Throttle position sensor cam sensor crank sensor coolant temp MAP thank you |
So far.... knock - 12589867 oil - 12677836 - looks different than the one i pulled out, might not be the same. Cam - 12561211 crank - 12560228 water temp - 12608814 MAP - 19236265 |
I have these sensors if you need... Not sure about extra crank. Most likely i do. They are used, but all working sensors. I don't keep spare junk lol |
© 2024 MH Sub I, LLC dba Internet Brands
