Converting from cathedral to rectangle port 03 silverado
Old Jun 15, 2019 | 02:32 PM
DustyNova442's Avatar
Default Converting from cathedral to rectangle port 03 silverado
I have a 408 ls using a 2002 6.0 block what all would be needed to add ls3 heads and a l92 intake to drop it into the 03 with the 03 computer etc
Old Jun 16, 2019 | 11:40 AM
bammax's Avatar
The heads and intake are the main thing mechanically. After that it's a throttle body that fits the intake and uses the same throttle control as the original. You don't want to end up trying to connect a throttle cable to a drive by wire tb. Then you make sure to connect all the sensors on the new intake and the mechanics are pretty much done. Depending on the exact setup you may need to do some clearancing on the top of the water pump. It seems to be a random thing so you won't know for sure until you set everything in place.
