Help. Ijnjectprs aren't firing
Old Jun 20, 2019 | 08:30 PM
68wagn's Avatar
Default Help. Ijnjectprs aren't firing
I need help,
i have a 2004 5.3 with a CBM 450 cam, and blue springs. I have an LS2 intake with a CMB adaptor plate to a dbw truck throttle body. My harness is a CBM. The throttle works , I have had my blue / green computer flashed. Engine will not run. If I " prime" the manifold it will fire right up, and burn off the fuel, then quit. I have 12v to all 8 injectors. I have 12v at the blue connector for all 8 injectors. I don't know what to do , any help Is appreciated
Old Jun 20, 2019 | 08:44 PM
moekluse's Avatar
Check your crank position sensor. I had that problem on my ls6. Was a brand new sensor from summit and it was bad. Easiest way to tell without hooking up an oscilloscope is to see if you have a tach signal. Mine wasn't showing a tach signal while cranking then I replaced it with a 15 year old sensor and cranked right up
Old Jun 20, 2019 | 08:54 PM
68wagn's Avatar
Ok thanks.
i replaced the crank sensor that came with the engine with a brand new Delphi " just to be sure". I'll put the original in, and give that a try
Old Jun 20, 2019 | 10:44 PM
00pooterSS's Avatar
Could also be the security system. It will allow the engine to run about 1 second and die.
If it's not that it's a cam or crank sensor issue. The computer flashes the ground to the injectors to fire them. So you can hook up a noid light and watch for injector fire or use a test light on the ground wire at the injector plug and watch for it to flash.
If you have a graphing meter ( I use a fluke ) you can tap into the signal return wire at the cam and crank sensor and watch for the graph to flash. The signal is too fast for the numbers on the screen, that's why you need an oscilloscope to watch the wave form pattern, or a graphing meter. Oscilloscopes are several thousand dollars, but a graphing meter is a couple hundred so I bought a graphing meter for that reason (to watch cam and crank sensor signals).
Old Jun 23, 2019 | 08:29 AM
68wagn's Avatar
I swapped out the crank sensor with the original, and no change. I'm going to wire up the original tach thru a Dakota digital converter box to see if I have a tach signal
Old Jun 23, 2019 | 08:57 AM
Old Geezer's Avatar
Try the tune/diagnostics forum?
Old Jun 24, 2019 | 11:03 AM
00pooterSS's Avatar
I don't know what car you have or how it's wired but on most vehicles the tach doesn't move during cranking.
Old Jun 24, 2019 | 11:06 AM
moekluse's Avatar
78 trans am with ls6 and a standalone harness. I checked it again today and I do have a Tach signal while cranking on my OBD reader
Old Jun 25, 2019 | 11:50 AM
00pooterSS's Avatar
yeah you may see it in a scanner, you said you were gonna hook up the original tach and check for signal, I thought you meant you were gonna watch the tach itself.
Old Jun 25, 2019 | 12:07 PM
moekluse's Avatar
My mistake. Not sure about tach but def on obd scanner
Old Jun 25, 2019 | 06:49 PM
John at CBM's Avatar
Hi, just saw this. Can you please give Sean a call at 909.291.7550 ext. 2004.
Have detailed info ready and we may be able to help you out. Thanks.
Old Jun 30, 2019 | 10:45 AM
68wagn's Avatar
Yes I am working with Sean. I appreciate all the help so far.
