Do you think I have a coolant leak in my head? 5.3L, 706 casting, pics inside
My 2003 Sierra with 5.3 LM7 has 86k miles on it, and recently gave me a low coolant light. I last flushed the system about 5 years/20k miles ago, and it passed a 15 lb pressure test recently with no issues. In researching potential areas for coolant loss, I learned about the water pump being a common leak area, and then opened the can of worms on the Castech cracked head issue.
I pulled my valve covers this morning - I am trying to track down a borescope in the hopes I can look for the Castech casting logo before pulling the rockers. The driver side looks clean and nice, but the passenger side seems to have a more orange/bronze color to it with a slight film on the inner valve cover. In the opinion of LS1tech, might this be a sign of a slight leak in my head?
Driver
Passenger
Driver on left, passenger on right
Driver
Passenger
Moderator
Received 1,835 Likes
706, 2003, castrch, coolant....
As cheap as factory heads are, grab a 862 used for $150 and slap it in. Change the oil, back in business and no fear.
Well, good and bad news. No evidence of a crack anywhere...but I do indeed have Castech 706 heads.
Now to start the hunt for a set of 862s.
Or do I pull the 241s off the TA and give it a heads/cam swap...?
Moderator
241 flows the same as 706 but worse compression. You would do better to look at prc 5.3 stage 2 or similar
Yup... pass side gets clean air coming in from the filter, driver's side is where dirty air is extracted by the PCV valve/orifice into the intake.
I've lived through the Castech crack issue, and I don't see it in your photos. You're still lucky at this moment.
