AC blowing threw Defrost Vents?
So I’ve checked the lines around the intake and there all good. The pcv valve was a little loose but I clapped it back up tight. The small line coming from the intake manifold is still connected an the check valve has all 3 lines still connected with no visible damage. The valve it’s self it pretty dry looking but like I said from what I can see there is no visable cracks. Would you lead towards the actuall switches them self’s?
