Catch can mount
Old Sep 6, 2019 | 06:50 PM
navyboys99ta's Avatar
Default Catch can mount
Are there restrictions on where you can mount a catch can? I have a Mighty Mouse catch can with the cylinder head mount but I’m installing a passenger side alternator mount and am out of room on top
of the engine ( I’m keeping the AC). I was thinking of mounting it low in the engine bay but didn’t know if it would be ok. Also is there a restriction on how long the lines can be the way I have it routed at the moment is close to 10’ long?
Old Sep 6, 2019 | 08:33 PM
Chris Paveglio's Avatar
Where ever you put it, make sure it's easy enough to reach and open the drain valve. And it's nice if it's easy to reach without putting the car up on the lift every time to drain. 10 foot is long but it actually might help to cool the air a bit for more condensation when it gets to the can... just speculating there.
Old Sep 6, 2019 | 08:35 PM
You're basically moving air. Actually, mounting it downhill of the engine will let any oil in the lines drain to the can. Where it mounts is not that critical
Old Sep 7, 2019 | 01:22 PM
Perfect thanks for the info
