Power loss with MSD intake
Quick run down of my setup.
73 Nova
Callies compstar 4340 forged crank, 6.125 forged rods, Wiesco 4.030 forged pistons
Comp cam 281LR duration 281/289, Lift .617/.624
317 heads
MSD atomic intake manifold
Warr 102mm throttle body
4l80e 3200 converter
4.11 gears
Holley DominatorECU
A 8.8 is almost 2 seconds slower than what that combo would run here in TN... I wouldn't think 5500 extra feet of elevation would make anywhere near that much difference.
What is your MPH and 60FT?
Also that combo would be just fine with a TBSS intake
Maybe someone else will chime in on the elevation but a 408 with healthy cam will run 6's with traction in a 3000lb car. If anything at all is holding it back it would be the 317 heads with lowish compression, but not a whole lot. Im guessing you plan to add boost?
Google says air pressure at 6000ft is 11.7 PSIA
(246/11.7)*14.7=309hp at sea level
Something isn't right.
Edit: MPH and actual weight, or any data would help
Last edited by Woodylyf767; Jul 29, 2021 at 12:19 AM. Reason: Don't want to blow up feeds
Go ls3 heads. I have stock ls3 heads on my 408 with a fast 102 in my Corvette. It makes 525 wheel and traps 108 ish in the 1/8th on the street .
