LS6 Intake repair
Old Aug 12, 2021 | 01:23 PM
AF1Strider's Avatar
Default LS6 Intake repair
Hey guys,
I was wondering if anyone here has successfully repaired a ls6 intake. I was putting my intake back on after replacing knock sensor and noticed the intake is cracked at the throttle body bolt insert.Its not cracked all the way through but its probably only a matter of time. The crack does extend into the TB gasket spot so I dont think its saveable but figured id check to see if anyone has had luck fixing this.
Old Aug 12, 2021 | 01:56 PM
You could likely epoxy it. The manifold is not a stressed part.
Old Aug 12, 2021 | 03:50 PM
AF1Strider's Avatar
I was thinking about it, but since it goes through the gasket groove and if it does break off it would mean only 2 bolts are hold the TB on I wasn’t sure if plastic epoxy is a worthy solution. I know people have used it with success elsewhere on the intake, but this affects the TB mounting. I haven’t found much on people having this area of the intake cracked, most of time it seems the back areas get cracked.
Old Aug 12, 2021 | 04:22 PM
pdxmotorhead's Avatar
JBweld sells a plastic specific putty epoxy. I found in general if their stuff sticks,, it doesn't let go.
I've used the metal version to repair a frozen tractor block cooling jacket. Lasted for years..
Old Aug 12, 2021 | 05:16 PM
sjsingle1's Avatar
I would use 3M epoxy over any other type of epoxy for repairs....the kind used for body panels.....not cheap but works well
Old Aug 17, 2021 | 01:16 PM
rv12's Avatar
You could plastic weld it. just melt it back solid. The intake doesn't need to be overly strong.
Old Aug 17, 2021 | 01:29 PM
I have called 3M before and if you know the materials your using they are very helpful..
