Pcv fitting for intake/fresh air
I need to put a port in my intake tube for the fresh air intake that goes into the passenger side valve cover. I suppose I could just make something out of a barb fottong with a nut. I want to put the port on the bottom of the intake tube to hide it so something with a nut to make sure it doesn't fall out would be ideal.
What is everyone using for a pcv fitting in their intake tubes? I saw a flush mount one with a rounded over nut but I can't seem to find it again.
I have my vacuum/pcv set up as follows:
Fresh air from intake tube -> pass valve cover.
Driver side valve cover -> top port of tbss intake
Power brake booster -> large port on back of intake
Does this sound correct? Thanks in advance for any help or advice!
