Tap here for mechanical oil sender unit?
Old 07-25-2004, 04:52 AM
GTS346's Avatar
Default Tap here for mechanical oil sender unit?
Is this where I am supposed to tap into for a mechanical oil sender unit?
http://www.geocities.com/monza95/oilsender.html
Old 07-25-2004, 10:40 AM
Cheatin' Chad's Avatar
Try this : http://xse.com/leres/ss/gaugepod.html
Old 07-25-2004, 04:40 PM
GTS346's Avatar
Thanks dude, thats a top link
Old 07-25-2004, 04:54 PM
no problem.
good luck
Old 07-26-2004, 08:19 AM
Thunder175's Avatar
Doesn't LGM make a new piece that has two AN fittings for an oil cooler as well as a plug for a temp sensor? Just curious...
Old 07-26-2004, 05:22 PM
WILWAXU's Avatar
There's some good links in this thread:
https://ls1tech.com/forums/generation-iii-external-engine/192782-oil-cooler-adapter-pn-15725587-a.html
LG Stuff:
https://ls1tech.com/forums/generation-iii-internal-engine/130524-lg-motorsports-ls1-engine-oil-cooler-installed.html
Old 07-26-2004, 06:04 PM
NataSS Inc's Avatar
The LG unit is not big enough to allow for a mechanical sending unit. You have to use an electric one unless you tap into the pan for a mechanical one.
