Header installation what did you
Old Aug 10, 2004 | 07:52 AM
HumpinSS's Avatar
Default Header installation what did you
use to get the car up high enought to slide the headers in
Old Aug 10, 2004 | 08:21 AM
BLKWS6's Avatar
A lift ....but if you dont have that then will need some real tall jackstands..
Old Aug 10, 2004 | 08:38 AM
Checkmate's Avatar
I used jack stands, it really wasn't that bad.
Here is a pic right after I slide the passenger side in.
Old Aug 10, 2004 | 08:56 AM
HASTINGSRJ's Avatar
I used jack stands as well...wasnt too bad....
Old Aug 10, 2004 | 11:53 AM
LoPeY's Avatar
When you use jackstands, it helps to have a floor jack that will go high enough as well. If you use the dinky emergency jack, you're going to have to put some sort of blocks beneath it in order to get enough height.
Old Aug 10, 2004 | 01:53 PM
Krab's Avatar
I also used a set of jack stands at the fron of the car, and rhino ramps for the rear tires. Use a piece of 2x4 on the K-member, and position the jackstands as far apart right under the 2x4. That should give you enough clearance to slide the headers in from underneath.
Old Aug 10, 2004 | 03:42 PM
glennhl's Avatar
Jack stands front and rear. I was worried that it wouldn't be high enough, but had plenty of clearance to put in the Stainless Works headers.
Old Aug 10, 2004 | 03:48 PM
nikon1999's Avatar
personally i dont feel comfortable with the jackstands set that high, lift was the way to go for me, being able to move the car up and down made it a breeze. Sometimes i needed to crawl under the hood to position the header, then get back underneath to wiggle it around, i dont see how i could've done that with the jack stands easily.
Old Aug 10, 2004 | 06:23 PM
Steve Burger's Avatar
LS1TECH Sponsor
I used 4 cinder blocks, 1 under each tire. This was more than enough room to slide hookers in and get access through the hood.
$3.00 at Lowes.
Old Aug 10, 2004 | 06:58 PM
mooleyz28's Avatar
ummm... I used to cinder blocks and two HIGH jackstands for the front and 2 smaller jackstands for the back. was MORE than enough room... Probably could have did it with the 4 jackstands only... took me about 4 hrs for the headers to remove the old **** and put the new stuff in... maybe 4 hrs... Easy stuff...
Old Aug 10, 2004 | 07:59 PM
zchgla's Avatar
if i use ramps in the back, and jackstands that are about say...20" would i have enough room? where should i place the jackstands? at what point should i place the jack in the front of the car to lift it?
Old Aug 10, 2004 | 08:20 PM
HumpinSS's Avatar
I went with the rapms in the back and a 4x4 up front to get it high enough, took me about 6 hours to do by myself
Old Aug 11, 2004 | 06:28 AM
Checkmate's Avatar
I wasn't to thrilled with having my car that high in the air either but it was either that or it wasn't going in plus it was at that height for only about 3-5 minutes. Just enough time to slide in the passenger side header, the rest of the install it was probably 6 inches lower.
Old Aug 11, 2004 | 07:53 AM
Simp's Avatar
I used jackstands and Im pretty sure they were standard size on the highest setting. Slide them under the car horizontally then turn them vertical when theyre underneath the car. The drive side header was a pretty big PITA for me, but it slid in eventually. Just keep workin on it and dont give up.
Old Aug 11, 2004 | 08:43 AM
Keenov's Avatar
Installed pacesetters on a 2000 SS with a lift. Headers slid in like Ricky Henderson
Old Aug 11, 2004 | 09:43 AM
mitchntx's Avatar
Cinder blocks!!!! eee-Gads
Laying on their sides, they have very low loading capacity. This is not a smart move.
I bought a set of truck/SUV jack stands as I too don't like extending the stands all the way up.
Old Aug 11, 2004 | 09:53 AM
Keenov's Avatar
$3.00 at Lowes.
Why not just use 4 ramps. Guess your life means nothing
Old Aug 11, 2004 | 10:57 AM
35thls1ss19's Avatar
Just put on QTP's and i used a lift, it made it very easy
Old Aug 11, 2004 | 01:51 PM
777's Avatar
777
can you get metal ramps at like lowes or something?
Old Aug 11, 2004 | 01:59 PM
02WS6Bird's Avatar
i have ramps...car dont clear them...so id haveta figure another way wiht a jack and jack stands when i get my LT's
