LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Will bad 02's rob horsepower? (https://ls1tech.com/forums/generation-iii-external-engine/208035-will-bad-02s-rob-horsepower.html)
ThackerSS Aug 24, 2004 07:15 AM
How much can a bad 02.. or multiples rob HP?
Can they make a car that is susposed to trap 109+ trap 106?
I know for sure both my front 02's are bad.. and throwing multiple codes a piece.. car doesn't seem to run too terribly bad except it is down on power.. not much.. but enough to tell something isn't right. Car has also only trapped 106 with an m6 car.. and I have almost all of the bolt ons aside from ls6 intake and pulley..
https://ls1tech.com/forums/images/sm...r_confused.gifSo.. how much HP can bad 02's rob?
can they also cause knock?
ThackerSS Aug 24, 2004 03:53 PM
bump?
Another_User Aug 24, 2004 04:06 PM
Probably only if the bad O2s are putting his trims positive and throwing off his af at WOT. I think.
Keenov Aug 24, 2004 04:10 PM
Not sure about robbing horse power. I have heard that they make your gas mileage suck though.
Did you run 109mph before? You can't just suppose your trap speed, you could have a factory turd :)
Since you are for sure they are bad, replace them. Then goto the track and let us know the results. I would like to know aswell.
ThackerSS Aug 24, 2004 05:09 PM
Car made 333rwhp after the headers, it was fine.
333rwhp and trapping 106? Don't believe so. https://ls1tech.com/forums/images/sm...ch/gr_jest.gif
MyLS1Hauls Aug 25, 2004 09:33 AM
If they throw off the LTFTs at WOT,then yes it can cause a power loss. I wouldnt expect it to make a huge difference though.
blubyeu2000 Aug 25, 2004 11:38 AM
shit im getting 8 to the gallon, maybe its my o2s
Keenov Aug 25, 2004 11:56 AM
Dunno, maybe your VTEC didn't kick in :chug:
Dal1as Aug 25, 2004 02:15 PM
Yes, bad O2's will hurt performance and hp. Especially if you're SES light is on (limp mode)
Another_User Aug 25, 2004 07:15 PM
That's definitely another good point.
Cerebrex Aug 25, 2004 07:17 PM
if the SES light is on, then you are probably losing quite a bit of power
© 2026 MH Sub I, LLC dba Internet Brands
