need a waterpump question answered! asap plz
ok me any my friend cracked my timing chain when we put the cam in. its leaks a little bit enough for the rents to want me to fix it quick!! how many bolts hold the water pump together. i saw i think 5? let me know! im doing this tomorrow or thursday. i would appreciate a quick responce. thanks again!
From LS1howto's oil pump replacement instructions:
Water pump removal: Now that the radiator is out you have room to work. Put a wrench on the belt tensioner, pull on it, and remove the drive belt. Unattach the 4 hoses going to the water pump (2 big, and 2 small) and then unbolt the water pump. There are 6 10mm bolts to get it off. The power steering will block access to one of the bolts so you'll need to use a box wrench or gear wrench here.
http://www.ls1howto.com/index.php?ar...45d023aa1b371a
-Mike
-Mike
-Mike
-Mike
