LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   What are my replacement options for ball'n'socket header flanges? (https://ls1tech.com/forums/generation-iii-external-engine/213884-what-my-replacement-options-ballnsocket-header-flanges.html)
JimMueller Sep 8, 2004 07:47 PM
I've got the Grotyohann headers with the ball'n'socket flanges, mated with his y-pipe. I'd like to finally replace this y-pipe, but want to avoid the leaks at the collector flange associated with the usual slip-fit tubing.
I currently have cats and want them on the new y-pipe as well. I don't want to deal with the smell and rasp of losing the cats. While I'd like a true dual solution, everything I've read indicates I wouldn't like the additional noise/resonance, nor cost (I wouldn't accept pre-axle dump(s)), nor loss of ground clearance from having to go under the axle.
It doesn't seem like anyone makes a y-pipe with this style of flange. What sort of options do I have without making it look like a hack job? I'm not terribly interested in replacing the headers just to change flanges. Can I cut off the ball socket, add an extension to the collectors and keep it looking professional and leak-free without welding?
The flange aside, I was considering using PPC's or QTP' s y-pipe. The other unknown is the new TA I'll be getting from Unbalanced Engineering. It's a complete new design and I'm not sure how compatible these y-pipes will be with it.
TIA!
Cheatin' Chad Sep 8, 2004 07:59 PM
Yes, you can just cut off the ball and socket and add extensions. I would weld these however.Standard exhaust clamps look bad and I just do not like them personally.
possible connections:
V-clamps such as those found on turbo systems
http://www.burnsstainless.com/Hardwa...lamp-Vband.gif
Standard Three bolt flanges
http://www.burnsstainless.com/Hardwa...es/3holes2.gif
Wiggins clamps
http://www.burnsstainless.com/Hardwa...s/wiggins2.gif
Or you an use a slip fit w/ stainless band clamps (no image)
CaptUSA Sep 9, 2004 01:46 AM
:thumb: Answers with pictures are few and far between. Well done Chad. :nod: Also, there was a different type of clamp talked about recently that was totally pimp... I don't remember what the hell it was called though. I keep wanting to say dragon something or other (but I'm sure that's not it). ... Anybody know what I'm talking about? They were gold in color..... ?? :confused: I'll look around, and hopefully come up with them.
CaptUSA Sep 9, 2004 01:52 AM
:shocked: Success!!! :razz:
https://ls1tech.com/forums/showthrea...ghlight=clamps
They were called pythons. The pictures are down now, but you should PM him and ask him to send you some. They look SOOO clean under there, you would hardly even want to put it under the car. :pimp:
CaptUSA Sep 9, 2004 01:55 AM
http://www.pi-thon.com/products.htm
This link is their main site. Give you a good idea of what they look like at the very least.
JimMueller Sep 19, 2004 09:26 PM
I've been reading complaints about apparently every major vendor's mail-order y-pipes not fitting and/or tucking up well to the chassis.
It seems there aren't any places in my area which do mandrel bent tubing :bang: This d4mn y-pipe needs to go. I need it tuck up better to the chassis so I can make a torque arm fit :mad:
Any ideas, fellas?
© 2026 MH Sub I, LLC dba Internet Brands
