LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Why won't my car start on the first try anymore? (https://ls1tech.com/forums/generation-iii-external-engine/237809-why-wont-my-car-start-first-try-anymore.html)
Z28Venom Nov 11, 2004 10:41 PM
Lately, whenever I try to start the car. It never catches the first time. It turns over, I stop, and when I turn the key the second time. It fires right up. It started doing this about 2 weeks ago now. I just now figured that this may be tied in to why the car randomly bogs down when I'm tryin to accelerate.
Has anyone else dealt with this? Any info?
ls1hybrid Nov 11, 2004 11:21 PM
at least it fires up :smokin2:
Tranzaman00 Nov 12, 2004 12:02 AM
Fuel pump going bad maybe?
PREDATOR-Z Nov 12, 2004 12:40 AM
That would be one of my guesses, but replace fuel filter first and a can of "red line fuel system cleaner"
If it is determined that your pump is going bad, check the NEW PnP RACETRONIX 255gph pump kit instead of replacing it with a stock one.
Also when was the last tune up (plugs etc...)
CAT3 Nov 12, 2004 12:53 AM
Mike, had the same issues right before I left, but here is what I noticed. Hop in the car, turn the key to the run position wait just a second or two, and then crank to start. I noticed if i hop in and immediately crank (whichI didnt realize i was doing til well into the troubleshooting) it wouldnt start right up, and sometimes would idle crappy for a bit. Maybe the same your experiencing maybe not.
Charlie
verbs Nov 12, 2004 01:47 AM
I have that exact same problem right now, and so does another one of my buddies....I've heard of the VATS system going bad causing this.....not sure to the truth of it.
I have a new Walbro 255lph that's pushing out plenty of fuel, so I doubt it's that.
Racetronix Nov 12, 2004 01:50 AM
A fuel pressure gauge will go a long way in helping to solve your problem.
DaddySS Nov 12, 2004 05:12 AM
Turn on the ignition and listen for the pump to reach pressure than turn it over.
Replace the fuel filter if you haven't already done so.
RD99SS Nov 12, 2004 08:20 AM
Check your fuel pressure, you might have a good fuel pump pushing out enough fuel, but the pressure regulator might be bad or on its way out...my $.02
Z28Venom Nov 12, 2004 09:25 AM
I replaced the fuel filter two weeks ago..
I also installed a Walbro 340 about 3 months or ago now.
The pump is definitely priming when I initially turn the key.
I did some searching, and I think that I might have contaminated the connector for the Crank position sensor. After putting the car back to stock, I forgot to reinstall the oiltube dipstick before I started the car. Everything in the region of the starter got covered with oil.
-Well at least I'm hoping those connectors getting oil on them may be my problem. I read another post where this happened. I'm gonna clean everything up this afternoon. If this isn't the case, I'll check on the FP regulator.
Beast96Z Nov 12, 2004 05:31 PM
I had the same problem when I installed my 255 lph in tank. The pump was brand new, but it would not start on the first try. The second try, however, fired right up. This happened every time, not hit or miss. Ended up, the check valve was bad in the pump not allowing it to hold pressure. I determined my problem by hooking a fuel pressure gauge up. When you keyed the ignition, the pressure would jump to where it was supposed to be, then bleed off. The pressure is supposed to hold steady. Get a gauge and check it. It only takes a minute and you'll know for sure. This was on a BRAND NEW pump, so anything is suseptable to faliure.
Z28Venom Nov 12, 2004 06:25 PM
Thanks for that tip.. I'll check it out tonight..
BTL FED Nov 12, 2004 07:16 PM
That is exactly what my Truck does, and I put a fuel pressure guage on it and it does exactly that pump primes, and then pressure falls to 0
CAT3 Nov 12, 2004 09:25 PM
Hmmmm....Walbro Quality Control sounds a little suspect now!
Z28Venom Nov 14, 2004 03:12 AM
Update on my starting and bogging problems..
Found the problem in 15 min this morning.
Connected fuel pressure guage onto the fuel rail. Powered up the pump, and the pressure went up to 26PSI and immediately dropped off. I opened the access hole that I cut during my Walbro 340 install.
The fuel line on the pump was completely swollen and disfigured. It had small hole towards the top, and the clamp on the top had started to cut into the line.
I went to Napa and purchased some high pressure / fuel injection hose. $16.99 for 24".
After swapping out the bad line, powered the pump up. 54 PSI and it held steady.
The car runs strong as hell now. We scanned the codes before repairing the pump, and the were P0171 and P0174 if I remember correctly.
Thanks for all the help.... The Z is alive once again..
PREDATOR-Z Nov 14, 2004 03:59 AM
Awsome!
FYI, a Racetronix pump harness should give an extra 4 psi (I think).
Perhaps you should contact them and find out. It got my Racetronix PnP pump kit from 58> 62 psi. (about $100)
jmX Nov 14, 2004 04:03 PM
Sounds like I'll be hooking a fuel pressuge guage up to my car soon. I've got all stock stuff, but my car has been doing the same thing.
35th SS Nov 14, 2004 10:50 PM
So what on to the tracks this fri. weekend.who knows firebird 13 might show up.good job Mike.
slayer1234 Oct 12, 2007 12:27 AM
hey whats up i just recently bought a 97 LT1 with 156000 miles and same shit has been happening it wont crank the first try i checked the pressure changed out the pressure regulator but didnt help the psi goes to about 45 and then slowly drops down.. it takes about 5 secs to start up and ideas what it might be??? fuel pump??
HardyKefes Apr 14, 2017 12:04 PM
I have similar problem and need help: Yukon Denali 2004 fuel pressure is immediately on 60 psi, after 2 or 3 seconds I hear a click, a relay de-energizes and the pressure drops immidiately to 0. Any idea please? It seems fuel pump is creating pressure just fine. As soon as I re-turn ignition key (not starting), relay comes on, pressure is immediately back to 60 psi, after 2 to 3 sec same thing, drops to 0 immediately.
© 2026 MH Sub I, LLC dba Internet Brands
