LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   TSP True Duals install Q's... (https://ls1tech.com/forums/generation-iii-external-engine/267694-tsp-true-duals-install-qs.html)
DOUBT IT Jan 27, 2005 02:45 PM
Just ordered TSP's Rumbler X system. I've seen people mention that you have to move the fuel lines for clearance. Anybody got any pics of this? I know where the lines are, I just would like to see how everything is oriented under the car.
Also, is removal of the rear seat needed if you bolt the hangers in? If so, which part of the seat, the bottoms or the seatback.
Any answers would be greatly appreciated.
:cheers:
tomaSS Jan 27, 2005 02:58 PM
I just pushed the fuel lines up as far as I could go wherever they touched the exhaust, sorry no pics. The rear seat bottoms need to be moved. They can be pulled toward the front of the car (from the back of the seat bottom) to gain clearance for tightening the bolts, no need to remove them.
Kennedy98z28 Jan 27, 2005 06:44 PM
I just turned the fuel line brackets upside down and that moved them up enough. As for the seats I already had them out. I don't have any pics.
© 2026 MH Sub I, LLC dba Internet Brands
