Z06 Intake:
Old Feb 21, 2005 | 10:48 AM
HAWKMAN_'s Avatar
Default Z06 Intake:
got a 99 LS1 w/EGR and want to get rid of it. is it ok to order a Z06 intake w/out EGR and cap it at the engine. or should i just get the one with the EGR and do the infamous EGR mod (cutting it) what's the best route to take on this one.
Old Feb 21, 2005 | 11:00 AM
blu98ta's Avatar
get rid of the egr! Get the car tuned and get rid of the egr. That is what i did. If you are not able to get the car tuned then just cut the egr and get the manifold with egr.
Old Feb 21, 2005 | 11:24 AM
87gnx's Avatar
Same here I got the egr cap and plug kit(came w/all to do the swap) netted about 15rwhp after ls1 edit tunung.
Old Feb 21, 2005 | 11:25 AM
Keenov's Avatar
Same as above, besides the last part. If you are unable to get it tuned, remove the EGR and live with the SES light until you can.
Old Feb 21, 2005 | 11:49 AM
BTLFEDSS's Avatar
Mines gone to get rid of it and it makes the engine look cleaner
BTLFEDSS
Old Feb 21, 2005 | 01:45 PM
2000Hawk's Avatar
i ditched my EGR and bought a cylinder head plate from thuder racing in black and it has Trans Am WS6 engraved into it. looks alot more spacious without it.
Old Feb 21, 2005 | 04:28 PM
FungusMungus05's Avatar
Yup what they said, made under the hood alot cleaner just get the tune afterwards no biggie.....................
Old Feb 21, 2005 | 04:33 PM
HAWKMAN_'s Avatar
thanks for the info people
Old Feb 21, 2005 | 04:34 PM
HAWKMAN_'s Avatar
where did u find this egr cap and plug kit?
Old Feb 21, 2005 | 07:00 PM
Wino's Avatar
Loose that EGR!
HAWKMAN- I've seen the cap/plug kits on ebay.
Old Feb 27, 2005 | 09:31 AM
HAWKMAN_'s Avatar
Originally Posted by Wino
Loose that EGR!
on ebay? cool, thnx
Old Feb 27, 2005 | 06:47 PM
KrazyDan's Avatar
say after the egr removal and tune, do you think it would pass california smog?
Old Feb 27, 2005 | 08:25 PM
1badV6's Avatar
You can take the EGR plate and cut it off and have the original plate welded so it is filled. I did this and it worked fine, use a hack saw or something and get it welded.
Old Feb 27, 2005 | 08:26 PM
1badV6's Avatar
You shouldnt throw a dtc for the EGR, I didnt and neither did my friends 99 SS!!
Old Feb 28, 2005 | 05:47 AM
JEB99TA's Avatar
On my old LS1 intake, I plugged the hole and removed the EGR and A.I.R. pump, then. I removed the two pump fuses. I bought a $2.00 plug from Advanced Discount Auto and just lived with the SES Light.
Later, I looked at the part# on my wife's 2002 Trans Am intake and went looking for a LS6 intake and installed it on my car ... turns out, it's the same part# as a 2002 Z06 intake. After the swap, I got the car tuned and it runs great.
Old Feb 28, 2005 | 08:56 AM
Dustin@PremierAutosports's Avatar
lose the egr and live with the ses light until you have a reason to need tuning. then the can delete the egr in the ecu
Old Feb 28, 2005 | 09:05 AM
777's Avatar
777
ls1speed.com carries the block off's and plugs in the exhaust section...
