LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Engine Fuseblock Question - What's Hot Key-On?? (https://ls1tech.com/forums/generation-iii-external-engine/284080-engine-fuseblock-question-whats-hot-key.html)
ChevyNo1 Mar 2, 2005 11:06 AM
I had changed the wiring for my tilton oil scavenge pump ( Incon kit ) to only run when the fuel pump does, ie only the first 3 seconds of ignition, or when the car is running. I'm getting an oil leak out of the passenger turbo and I'm wondering if that's my problem. So I want to wire it in to a fuse that is only active when the key is in the ON position. Which one can I tap into?
- Dug
technical Mar 2, 2005 12:47 PM
I'm going to go out on a limb and say IGN.
ChevyNo1 Mar 2, 2005 01:31 PM
DOH! I think you're probably right ;) Thanks
© 2026 MH Sub I, LLC dba Internet Brands
