LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Mac's Install... questions (https://ls1tech.com/forums/generation-iii-external-engine/291670-macs-install-questions.html)
macool68 Mar 17, 2005 02:47 PM
I'm getting ready to install a set of Macs next week and was hoping someone could help me with a few questions. Search function availed little.
1. Will I need o2 extensions? If so, how many? When I was about to install LT's, some said that I only needed one for the passenger side. Is this still true with the Macs?
2. I've ordered a new set of GM gaskets, but have heard that I can reuse the stock manifold bolts. The difference is that my car has 115,XXX miles on her; would anyone suggest I can still reuse them?
3. I'm a header virgin; any quotes on the amount of time I'll need on this?
TIA,
David
jrp Mar 17, 2005 03:05 PM
http://modernmusclecars.net/forums/a...=headerinstall
macool68 Mar 17, 2005 03:17 PM
Thanks! Excellent write up
Benjamin Russick Mar 17, 2005 03:34 PM
I didn't need extensions when I installed the MACs. I also re-used the factory bolts with no problems. I have Stage 8s on my LTs, though...
jmm98LS1 Mar 17, 2005 04:51 PM
I didn't use extensions, but the driver's side was pretty tight. I reused the stock gaskets and bolts, everything seems fine. I installed mine totally by myself on jackstands in the garage and it took about 12 hours over a weekend. I could probably do it in half the time now that I've done a set.
© 2026 MH Sub I, LLC dba Internet Brands
