LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   For those with MAC's\MAC ORY (https://ls1tech.com/forums/generation-iii-external-engine/306427-those-macs-mac-ory.html)
JEB99TA Apr 14, 2005 08:43 PM
:secret: Just wanted to share information in hopes of helping people in the same situation I was in. My MAC ORY collector was a little bit smaller than my Borla Intermediary pipe ... couldn't get it to seal ... the original narrow band clamp just would tighten it down enough to seal it.
:drive: I hauled ass down to NAPA and picked up a 2 3/4" long (or round) stainless steel band clamp. It's about 4" wide ... torqued it down and it literally molded like a glove to the contour of the collector and I-pipe ... perfect seal!!!! I was so glad because I had thought about either a custom ORY for about $200.00 or welding the damned thing and messing up my Borla I-pipe. :cry:
Hope this helps somebody :nod: :headbang: :rock: :shakinass :thumb: :wavey:
JRracing Apr 14, 2005 11:43 PM
I just delt with this to day. I just put on a new GMMG last night & the I pipe had a pretty good gap in it. I tightned it all the way, it still had a little gap. So I took a cut off wheel on a die grinder, & cut a few small slits down the I pipe, about 1.5'' down. Under the clamp. That takes some metal out so it can collapse down to size. Worked fine. Good info though. ;)
JEB99TA Apr 15, 2005 05:50 AM
I had thought about doing that. The difference is this. I plan on going true duals eventually and I didn't want to take metal out of the I-pipe ... for when I sell my Borla catback. My I-pipe (as most I-pipes do) has slits cut into it but they are just not wide enough ... thought about widening them a bit to do the same thing you did. You probably plan on keep your GMMG permanently. I'm glad you overcame the issue 'cause I know how it feels to cure such an aggravating issue, when it comes to exhaust. :D
JEB99TA Apr 15, 2005 06:48 PM
tttt ... ttttt
jmm98LS1 Apr 19, 2005 08:26 AM
Thanks for the info! I went to Napa and ordered one of those band clamps and threw it on last night. It sealed it perfectly! I haven't heard my car with out an exhaust leak for so long, I forgot how good it sounded. :headbang:
JEB99TA Apr 20, 2005 12:48 PM
If it helped one person, it was well worth posting. I had nearly given up on
mine EVER being right with out an expensive solution. Thanks for posting the results. I'm glad it helped you. :drive:
dug Apr 20, 2005 12:56 PM
I replaced the small collector with the flowmaster collector. Its a true 3"
PREDATOR-Z Apr 20, 2005 01:59 PM
I just had the shop enlarge the collector end and with a 4' clamp no more vibration and leak.
JEB99TA Apr 20, 2005 05:07 PM
Predator-Z ... you got MAC's too, man !?
AWESOME!!!! :)
DJ_951 Apr 21, 2005 07:39 AM
I'll have to try that. Thanks for the info.
© 2026 MH Sub I, LLC dba Internet Brands
