LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   TD's into a GMMG catback. (https://ls1tech.com/forums/generation-iii-external-engine/321789-tds-into-gmmg-catback.html)
ninety9ta May 14, 2005 04:51 PM
I plan on purchasing the GMMG chamber exhuast as soon as i have the money to. (Test drove a t/a with the GMMG, and it was UNBELIEVABLE!) And i was wondering if it's possible to make a true dual system into a GMMG catback.
Covet May 14, 2005 05:03 PM
I'm also rather interested in finding the answer to this.
blkZ28spt May 14, 2005 05:58 PM
What you want is true duals with sweet thunder chambered mufflers. ;)
KrazyDan May 14, 2005 07:57 PM
saw a tread about 3 weeks ago with pics of this. Cant remember who it was. It was an awsome set up. Nice and clean. If you look hard enough, im sure youll find it
Redneck Z May 14, 2005 08:08 PM
QUOTE: What you want is true duals with sweet thunder chambered mufflers.
:metoo:
I agree with this. This should sound the same as TD's with the gmmg, only much cheaper.
snake charmer May 15, 2005 12:13 AM
Yeah, I had seen the same pic of this a couple of weeks ago, and it was a pretty bad setup!
cyphur May 15, 2005 02:06 PM
talking about this setup?
http://www.sweet-thunder.com/images/testimonials/13.jpg
buying a GMMG only to run duals to it is pointless. get duals w/sweet thunders, or buy the GMMG catback and run the catback. neither will be cheap, but the GMMG is cheaper if you plan on running the exhaust out the back.
00Z28 Camaro May 15, 2005 04:26 PM
looks like it would tuck up nicely
© 2026 MH Sub I, LLC dba Internet Brands
