QTP LT's and Kooks y pipe I hear a lot that QTP y pipe is crap(from people that have it). They suggest the QTP headers with the kooks y pipe. Will this combination fit??? Anyone else with any problems? THanks |
I would like to know the answer to this question also. |
i asked and talked to afew speed shops, and looked into myself and the answer is that it will fit with adjustments made to either your collector on your headers, or cutting the Y up...kooks makes there collectors shorter then QTP, so you'd have to cutt like 1'' or 2'' 's off the collectors to get the Y to line up with the floor board correctly...kooks Y's have flat spots in it for floor board clearence and if you dont modify stuff, it wont line up right...but yes it can be done....or you can just do what i did and get a mufflex ORY... Jon |
Originally Posted by SilverStreak1830 just do what i did and get a mufflex ORY... Jon Is the mufflex a direct fit?? do you have any pics?? |
just get the kooks lt's to go with the kooks y pipe. same design. same material |
| All times are GMT -5. The time now is 02:04 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
