LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   apparently i'm retarded (https://ls1tech.com/forums/generation-iii-external-engine/333714-apparently-im-retarded.html)
BrandonDrecksage Jun 8, 2005 01:51 PM
I went to install my slp lid today on my 01 ss. well i was just following the directions...got out the whole stock intake assembly. I went to separate the maf from the stock lid and baffles..and it wouldn't come off. it would twist a little to each side and the clamp was as loose as possible, but the maf wouldn't separate from the lid? is there a trick to it? I didn't want to force it and break something.
Dustin Jun 8, 2005 01:53 PM
use a screwdriver to pry it off, that is what i have always done, just dont scratch it up too much, its pretty damn hard to get off by hand, lol.
BrandonDrecksage Jun 8, 2005 01:55 PM
I had a screw driver in my hand...but didn't want to break anything..lol so i put it down and put the stock assembly back in...guess i'll get back on it saturday when i put my catback in.
BigE Jun 8, 2005 01:59 PM
I used a friend. lol I had him hold the lid while I pulled and twisted the MAF free. If you are friendless at the moment, you could try sitting on the edge of a chair or bench, placing the assembly between your legs with the MAF side towards you and the edges of the lid under each leg and pulling/twisting it out. Be careful using any screwdrivers and such. It's very easy to damage the MAF and MAF screen (if you still have one).
Z28Venom Jun 8, 2005 02:00 PM
There's actually a little notch on the side that is perfect for prying with a large flathead screwdriver. Don't worry, I doubt that you'll damage anything.
patSS/00 Jun 8, 2005 02:01 PM
Use a hairdryer, get the outer plastic really warm, then it will come right out.
BlutVonSchwachen Jun 8, 2005 02:01 PM
You can also try a hair dryer to heat up the plastic, helps a little.
BrandonDrecksage Jun 8, 2005 02:09 PM
thanks...I noticed you have a tsp rumbler...thats what i'm installing saturday...was it easy to put on?
CWallen Jun 8, 2005 02:15 PM
I used the, "hold lid between my legs and pull on the MAF" method when I separated my MAF and lid. It feels like it wont come out but if you pull hard enough it will come loose.
BrandonSS Jun 8, 2005 02:18 PM
Like the other 2 said above... hairdryer will work like a charm... get it warm and it will come apart very easily.
Wnts2Go10O Jun 8, 2005 02:39 PM
with the holding it between ur legs and pulling method, be careful not to nail urself in the face..:jest:
CWallen Jun 8, 2005 02:47 PM
yeah you have to be ready to dodge or :)
JerseyLS1TA Jun 8, 2005 03:38 PM
I was holding it between my legs and thought that I would hit myself in the face, like already said :jest: Then I decided to get a screwdriver and pry it out, much easier.
Redneck Z Jun 8, 2005 03:47 PM
Rather than pry at it, I think it's better if you use the notch with a wide head screwdriver and twist the screwdriver. This seemed to work great, and you don't have to put the screwdriver between the plastic and MAF. This way you don't scratch up the MAF.
SOM98TA Jun 8, 2005 03:50 PM
are you guys being serious with the hairdryer?
or are you just trying to ruin this poor guys lid?
bboyferal Jun 8, 2005 04:12 PM
:lol:
Yeah... This was my technique, too. I put it between my legs, held my breath, and starting shaking around like a pager or a celly vibrating across a table. :boiling:
I thought I was gonna tear a testicle when it finally came loose. I fucked up my fingers... Yeah, that was the stupid way! :bang:
BigE Jun 8, 2005 04:20 PM
Umm ... watching out for body parts (especially Big Jim and the twins, Neil and Bob) should be a given in any activity.
BShack Jun 8, 2005 05:35 PM
Originally Posted by bboyferal
:lol:
:rotflmao: :funny: :rotflmao:
Holy crap, I think I just ruptured my gut from laughing so hard. God I love this site. :jest:
Shack
The old man Jun 8, 2005 06:28 PM
I used a heat gun.. Had it apart in about 30 seconds :drive:
© 2026 MH Sub I, LLC dba Internet Brands
