LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Car won't crank (https://ls1tech.com/forums/generation-iii-external-engine/334222-car-wont-crank.html)
Houston Jun 9, 2005 11:46 AM
Car won't crank
2000 SS - M6. The car won't crank when the key is turned to start. The AC and Cruise Control don't work either. The car can be started by hot wiring it from the starter relay. The VAS has been disabled.
I know the battery is good, as well as the starter.
I've tried the extra key and checked all the relays. The clutch disable switch checks out too.
My guess it is either the ignition switch or Body Control Module.
Has anyone else had this problem and how did you fix it?
Thanks.
CWallen Jun 9, 2005 11:52 AM
Thanks.
My guess would be the ignition switch but I dont know how to test it. Someone chime in here.
2001NBMZ28 Jun 9, 2005 01:20 PM
I'm just guessing, I know you said you checked all the relays - but sounds like it could be the "IGN" (Engine controls, cruise control, air conditioning) relay.
Houston Jun 10, 2005 10:37 AM
The test indicated by the GM shop manual say it is the BCM. I hear it isn't easy to get to.
Xtnct00WS6 Jun 10, 2005 03:19 PM
Thanks.
Just a guess here...but could it be a blown fuse? Try pulling a few of them and leaving them out for a min. while the battery is still connected. I took my gauges out and then my car wouldn't start. Pulling a few fuses got it working though! Good luck!
Cstick Jun 10, 2005 04:52 PM
Have not seen anyone suggest the nuetral safety switch, or clutch switch in your case. Jumper wire should be able to test it. Switch around some relays but I doubt that is the problem. There could be a fuseable link in the wire going to the "S" terminal on the starter. I do not know if our cars have them though.
IGN Switch - Does your radio come on when the switch is in the ON posistion? Does the radio go off when you turn it to the start position? If this is all OK I bet that switch is OK.
Good luck
© 2026 MH Sub I, LLC dba Internet Brands
