LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   please help, engine wouldn't turn over! (https://ls1tech.com/forums/generation-iii-external-engine/338012-please-help-engine-wouldnt-turn-over.html)
Shooter_Jay Jun 16, 2005 10:02 PM
After work today I went to start my car and the lights were on but nobody was home. The guages lit up fine, but it was like I wasn't pushing in the clutch. The starter didn't even click. After a few failed attempts including resetting the alarm, I ended up pop-starting it in 2nd gear...real easy by the way, but that's not the point. So anyway, I shut it right off and tried again, and that time the starter cranked over normal and she started right up.
I need to make sure this doesn't happen in a BAD PLACE! Any ideas what might have caused it?
BrandonSS Jun 16, 2005 10:18 PM
I've seen this happen a ton of times on my buddies cars and ONCE in MINE when i first got it. I have no idea why and neither do they. They are also M6 as well as myself. :dunno:
technical Jun 17, 2005 11:45 AM
Things to consider:
Clutch switch beginning to wear out
Started relay beginning ""
Starter itself beginning ""
Battery or battery cables ....
If it is the battery, then double check the alternator. Because that's 99.9% of the time the reason the battery went.
Harley-Davidson88 Jun 17, 2005 01:24 PM
I'm willing to bet money that it is the resistor on your ignition key. I had the same thing happen on my car and it baffled me for a while. I cleaned the key good and carried a spare just in case, but I never needed to even use the spare. That was the culprit. Was the "security" light flashing in the gauge cluster?
Shooter_Jay Jun 17, 2005 05:03 PM
didn't notice security...anyway I was suspecting the clutch switch, but because it worked fine after I pop-started it, it made me think it's some computer issue, the resistor theory sounds interesting...
© 2026 MH Sub I, LLC dba Internet Brands
