LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Installing LT's, ORY soon - questions..... (https://ls1tech.com/forums/generation-iii-external-engine/364330-installing-lts-ory-soon-questions.html)
wile9coyote Aug 11, 2005 03:22 PM
I am installing a set of Jet Hot LT's with a Jet Hot ORY pipe as well - my question is this - I just bought this camero and think that it has been lowered, seems a little low to me anyways. I am concerned that when I install this ORY it will hand down too low - it is a 3" pipe all the way around and will be way larger than the pos stock ypipe that already is hanging a bit low.... Anything I can do about this? Are there stock height aftermarket springs out there? Any help would be appreciated - thanks - stevet
Xtnct00WS6 Aug 11, 2005 04:25 PM
Keep it lowered, you'll be fine. Just make sure you tuck the Y up there good.
marcus769 Aug 11, 2005 04:31 PM
I just bought this camero and think that it has been lowered, seems a little low to me anyways. - thanks - stevet
*****************CAMARO************************
TransLS1 Aug 25, 2005 11:38 AM
hey how did the install go? im doing my next weekend i think i will have a shop fab-up a y-pipe for me but let me know how it went? and on a 98 the coil packs are not on a coil rack,they come off one by one right?
NassyVette Aug 25, 2005 11:43 AM
:jest:
98z28chevy Aug 25, 2005 09:57 PM
TransLS1 yeah 98 LS1 have coils mounted right to the valve cover 2 bolts for each coil 10mm i believe are the bolt sizes.
EPP Aug 26, 2005 06:42 AM
It is much easier to use the Y Pipe that is made by the same brands of headers. A muffler shop made Y Pipe is most likely to be made without using mandrel bent tubing, meaning you might have some restriction in there. The Hooker and Jet Hot headers tuck up really good, and their Y Pipes will not pose a problem on lowered cars. Bob
© 2026 MH Sub I, LLC dba Internet Brands
