? on poly motor mounts by prothane
Old Aug 12, 2005 | 02:24 PM
SVC707's Avatar
Default ? on poly motor mounts by prothane
is there a difference in the left and right sides im looking to purchase off someone on this board. they did the driver side already so my question is. is the side they have left only good for the passenger side?
Old Aug 12, 2005 | 02:33 PM
Brandon Boomhauer's Avatar
I'm almost positive they are the exact same on both sides.
Old Aug 12, 2005 | 02:38 PM
SVC707's Avatar
thanks.. just s few more opinions and ill prolly get em otherwise i dont want to get stuck trying to install it in the driver side and find out i wasted my time that it wont fit
Old Aug 12, 2005 | 02:40 PM
cook_dw's Avatar
Nope exact same. Put both on mine when I had the "k" out of it. You are only getting the inner piece you reuse the clam shell.
Old Aug 12, 2005 | 02:48 PM
thunderdan74's Avatar
Make sure you have a good drill. the rivets holding those clamshells togther are like 3/8". I took me a while to get it done with a dremel and my chordless drill...PITA. I did mine at the same time I did the headers to prevent the headers from banging into anyting under hard acceleration.
Old Aug 12, 2005 | 09:53 PM
OldeSkool's Avatar
drill the rivits out with a drill press if you got one. like buttah
