Anyone running Single plane & efi on LSx motor
High guys
Was just wondering if anyone was running a single plane manifold with injector bosses & running EFi, 1000-1200CFM throttle body sitting on top
I was just checking as i think it would a cool idea for my 80's curcuit track car,
big shielded air filter sitting on top of the motor - thru the bonnet with reverse air dam scoop drawing in the cold air..
Old school look, new school motor
I thought elderbrock where doing one - carbon fibre look about it
2, & more importantly do they flow more than ls6/ls2, fast etc ??
Cheers
Cheers
Bond, your going to be hard pressed to find many believers of the 4V setup.
There are a few guys with Blowers running the GMPP intake and a 4V throttle body but besides looks, the performance isnt as good as say a standard LS6 intake.
Tunability is another slight issue, havent seen too many 4V EFI setups that idle the greatest, most are setup with a high 1000rpm idle to smooth them out.
But for looks there great and always work when theres a turbo or blower next to it, but NA I would save my $$ and get a FAST.
Cool thanks for that, I wasn't how they went, especially since not a lot of people where running them.
I just thought it should be concidered, due to the possibity of getting cold air easier, but not if is going to cost me in performance
Cheers
Cheers
A little bit of reading for you
https://ls1tech.com/forums/showthread.php?t=105407
https://ls1tech.com/forums/generation-iii-external-engine/112195-new-edelbrock-ls1-intake.html
https://ls1tech.com/forums/generation-iii-external-engine/148639-new-carb-ls1-setup-made-40-hp-over-ls6.html
https://ls1tech.com/forums/generation-iii-external-engine/158658-gmpp-ls1-intake-availbility-update.html
https://ls1tech.com/forums/generation-iii-external-engine/168311-war-intake-accel-teaser-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/173568-more-war-gmpp-intake-pictures-big-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/198601-gmpp-singleplane-tested-new-popular-hotrodding-mag.html
