Anti-seize on header bolts? Just got my headers on and was wondering if I should have used some anti-seize on the bolts that go into the cylinder head? While were at it should I put it on the spark plugs too? |
I didn't.I used the old bolts ans seemed to work fine.Retorqued after 1000 miles just in case tho... |
Anti seize on the spark plugs a good idea. A lil' locktite on the header bolts not a bad idea either. |
My bolts had thread locker on them from the factory. A drop or two of high temp red loctite is all you need. This is what is specified by GM. Chris |
© 2024 MH Sub I, LLC dba Internet Brands
