Making mac's equal pacesetters?? i bought a set of used mac mids and y pipe, simply because it was relatively cheap and couldnt pass them up.. i bought a new flowmaster y collector ( the mac one was bent) and ive heard about grinding down the welds at the top of the header (where they bolt to the head). my question is w/ the new collector and grinding down the welds, will that equal the power of pacesetters or even increase the mac's abilities?? also i drive a 98 A4 ws6 - ls6 intake, bbk 80mm tb, slp maf, slp lid, and the exhaust will be ran out of a cut out.. what kind of power increase can i expect to find with these and an asp underdrive pully.. my last #'s were 316/326 thanks, dustin |
At least 20rwhp and 15ft/lbs torque. They make power. Just look at them. Everything is a straight shot without any sharp bends. I think the 2.5" ypipe hurts them but then again people run 2.5" duals without any losses. |
Originally Posted by dug At least 20rwhp and 15ft/lbs torque. They make power. Just look at them. Everything is a straight shot without any sharp bends. I think the 2.5" ypipe hurts them but then again people run 2.5" duals without any losses. 2.5" duals will flow double that of a 2.5" Y. There are 2 pipes with a dual and each pipe only has to contend with 4 cylinders, as opposed to 8 with the Y pipe. |
Originally Posted by ktktransam i bought a set of used mac mids and y pipe, simply because it was relatively cheap and couldnt pass them up.. i bought a new flowmaster y collector ( the mac one was bent) and ive heard about grinding down the welds at the top of the header (where they bolt to the head). my question is w/ the new collector and grinding down the welds, will that equal the power of pacesetters or even increase the mac's abilities?? also i drive a 98 A4 ws6 - ls6 intake, bbk 80mm tb, slp maf, slp lid, and the exhaust will be ran out of a cut out.. what kind of power increase can i expect to find with these and an asp underdrive pully.. my last #'s were 316/326 thanks, dustin And no the mids ultimatley will not produce as much power as Pacesetters. This is beacause the Pacesetters are long tube headers and the primaries are longer. For a more technical explanation take a look at the sticky about exhaust and mods. There is some really good info about headers in there. |
Id rather have pacesetters too but if you already got em might as well put them on. |
My stock internal car made more power/torque, and better track times with Mac's/duals than it did with Pacesetters/duals. Everything else about the setup was the same. |
| All times are GMT -5. The time now is 06:15 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
