Anybody done TB Bump Stop mod?
it seems to me that it would free up a couple ponies, but probably will not be a big enough gain to feel on the "SOTP dyno"
I think its the blue wire from the throttle position sensor that you want to tap into with the voltmeter. Then keep grinding down the bumpstop and checking it every so often until you get to 4.7v. Anything more will be more than 90 degrees and set an SES light. I stopped at 4.69 volts and yes.... I could feel a difference. SOTP that is...
i had just found it too and was about to post it for future searches.
https://ls1tech.com/forums/showthrea...78#post3914578
