Intake Questions (MAP Sensor Related)
Old Dec 7, 2005 | 10:26 AM
josh99ta's Avatar
Sold The Fun Stuff :(
Default Intake Questions (MAP Sensor Related)
How difficult is it to swap over a MAP sensor from one intake to another, and do LS1 and LS6 intakes share the same MAP sensor? Do I need any special gaskets or are they built into the sensor, and does anyone have any tips on easy removal (I've heard it can be a real pain to get an old one out)? Thanks in advance for any help.
Old Dec 7, 2005 | 12:06 PM
conan's Avatar
The MAP sensor should pull out of the back of the intake. There is a little tab on the intake that the sensor slides on to. It has a rubber O ring on the nipple so you dont need a gasket. The ls1 and ls6 are the same. You might have to unbolt the intake and slide it forward to get at it.
