exhaust painting
Old Dec 13, 2005 | 02:32 PM
jimmy 2 Times's Avatar
Default exhaust painting
When i did my true duals, we just painted them, and bolted them up (just to clean them up temprarily). Well now the paint is peeling, and i want to try an fix it over the winter. What is the best way to keep the paint on the pipes?
prep work, paint, etc etc
thanks
Old Dec 13, 2005 | 03:00 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Did you use Hi-Temp engine paint? If not I would go that route.
Old Dec 13, 2005 | 03:32 PM
yes, i used high temp paint, but still it is starting to flake and peel. I did not do any prep work the first time, and that is my main concern now, what should i do?
Old Dec 13, 2005 | 03:52 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Snag some stainless exhaust...pretty much anything with heat like that is gonna peel over time.
Old Dec 14, 2005 | 10:18 AM
jmm98LS1's Avatar
I used flat black bbq grill paint on my cutout turndown and it's held up very well for 8 months so far.
Old Dec 15, 2005 | 09:49 AM
do you think that i should scuff the pipes up with some sand paper first, then some primer? or should i just re-spray it, and call it a day?
btw, the original paint job was done in the worst ideal weather condiditons
Old Dec 15, 2005 | 09:53 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Clean it, scuff it, prime it, and respray it in more ideal conditions. Mine did this initially, but I've since repainted it and it seems to be holding up better. Lots of people have had luck with the BBQ paint too...
Old Dec 15, 2005 | 09:59 AM
BIZZARO's Avatar
A good once over with paint thinner to clean them works great, seems like new exhausts have an oily residue on them which will prevent a good application of paint. I painted one of my other exhausts with a few coats of 1200 degree black BBQ paint and then a few coats of 600 degree engine paint. The engine paint had a little gloss to it and made it look good, and seems more durable.
Old Dec 15, 2005 | 10:03 AM
01 Red WS6's Avatar
I've seen BBQ grill paint used a lot and it seems to work really well
Old Dec 15, 2005 | 10:05 AM
Steve Burger's Avatar
LS1TECH Sponsor
Try POR 15 high temp paint.
Old Dec 15, 2005 | 10:10 AM
MeentSS02's Avatar
Good post, and I'll agree on the oily residue part. I really need to pull my exhaust back off and really get a good coat of paint on it.
Old Dec 15, 2005 | 10:57 AM
Lane's Avatar
Scuff them up with some scotchbrite and spray 'em with Krylon BarBQ black.
Old Dec 15, 2005 | 11:20 AM
Full-Force's Avatar
thats exactly what i just did with the last set i built, scotchbrite and krylon bbq black
Old Dec 15, 2005 | 11:50 AM
Flawless02SS's Avatar
I used DupliColor Hi temp primer and paint on mine and mine still look new! No peeling here....
