carburated ls1 intake manifold questions
Has anybody tried it ??
will it work on all lsx motors, heads ?? Sorry new to the lsx motors.
I`m thinking of building a all aluminum lsx motor for my 93 notchback mustang.
Should weigh about 2300-2400 when done
I think it would be alot cheaper and easier to do the carb.
Also whats the differance in the ls1 and zo6 blocks ??
Any help would be great.
The LS1 and LS6 blocks, crank and pistons are identical. The differences between the two engines are heads, cam and intake. So dont pay extra for an LS6 if you intend to change all that
Here's some reading for you:
https://ls1tech.com/forums/generation-iii-external-engine/105407-carb-intakes-ls1-s.html
https://ls1tech.com/forums/generation-iii-external-engine/112195-new-edelbrock-ls1-intake.html
https://ls1tech.com/forums/generation-iii-external-engine/148639-new-carb-ls1-setup-made-40-hp-over-ls6.html
https://ls1tech.com/forums/generation-iii-external-engine/158658-gmpp-ls1-intake-availbility-update.html
https://ls1tech.com/forums/generation-iii-external-engine/168311-war-intake-accel-teaser-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/173568-more-war-gmpp-intake-pictures-big-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/198601-gmpp-singleplane-tested-new-popular-hotrodding-mag.html
https://ls1tech.com/forums/generation-iii-external-engine/267311-carb-ls1-intake-converted-efi.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/305750-why-more-people-not-running-gmpp-intake.html <<pictures
https://ls1tech.com/forums/dynamometer-results-comparisons/311005-spm-hptuners-dyno-results.html
https://ls1tech.com/forums/generation-iii-external-engine/314549-carbed-intake-converted-f-i.html
https://ls1tech.com/forums/generation-iii-external-engine/320023-gmpp-carb-efi-conversion.html
https://ls1tech.com/forums/forced-induction/327044-new-intake-arrives.html
https://ls1tech.com/forums/generation-iii-external-engine/334178-who-do-machining-gmpp-single-plane-manifold.html
https://ls1tech.com/forums/generation-iii-external-engine/354540-vic-jr-intake-ls1.html
https://ls1tech.com/forums/generation-iii-external-engine/379735-edelbrock-victor-jr-intake-pics-specs.html <<picture
https://ls1tech.com/forums/generation-iii-external-engine/381677-various-single-plane-intake-pics-big-pics.html
https://ls1tech.com/forums/generation-iii-external-engine/392724-putting-carb-ls1.html <<Lots of Pix
https://ls1tech.com/forums/generation-iii-external-engine/414468-gmpp-intake-vs-edelbrok-victor-jr-ls1.html
Most are FI setups, but a carb could be used in those setups.
