Can't pass Smog? Any Info would be greatly appreciated!!! I have a 99 TA that I'm trying to smog after a battle with the wiring harness that melting to my headers. I took it to the dealer to rewire and reroute around the SLP Longtub headers. Then I took it to a smog station and failed the NO (PPM) at 15mph "max limit 430 my measure is 1170". When the wires melted they took out the Crankshaft Sensor and caused the engine to back fire severely enough to blow out both CAT's!!! Could this backfiring destroy the EGR valve? Any knowledge you have on Smoging would be greatly appreciated. PS. The car passes at the 25mpr marker with no problems. Thanks, Jeremy |
If the EGR valve were destroyed you ought to have a code from it. Low speed will put the cats colder and possibly less effective. However I suspect the trouble may lie with the O2 sensors, headers making them run cold and swing wide & slow; every over-excursion is a high-emission "event" that the cats have to bust down. I am no emissions expert (only smart enough, to not live in places where the State thinks it's your Mother). If you're going to throw replacement parts at it, the O2 sensors ('vette rears as replacements) are a good place to start. I would also make sure that, with the CKP wiring replaced, you had a crank relearn that ran OK. |
Thanks for the info I'll see what the O2 Sensors do. When I took the CATS off last time they were partially covered with CAT innards covering them. So they may be the culprits. |
| All times are GMT -5. The time now is 08:48 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
