People w/ Jet hot headers How was the install? did the headers go in easy? any problems with them? thanks. |
peice of cake, no problems. while you're in there, i would highly recommend a set of poly motor mounts. |
we pull off the passenger side coil pack it gives you a ton of room! |
Install was pretty easy but I did have to notch my drivers side k-member so the one tube wouldn't hit/rub on it. Remove the steering linkage and it should slide right up in with no problem... |
Went in easy for me. Notch your K member on the drivers side as previously said. I got mine in there and didn't knotch it and it wasn't fun trying to notch it with the header on. Cars equipped with the ls6 block may have to have a little of the material ground off the block tab on the drivers side as well. I had to do this when helping my friend put them on his 02 SS. |
© 2024 MH Sub I, LLC dba Internet Brands
