Hendricks Machining Ported Throttle Body 1 Attachment(s) I finally got around to porting my throttle body this week. I think it turned out well. I thought about epoxying the holes, but I didn't find what I was looking for to do it with, so I left it be. Took the pic with my cell phone, so it's not that fancy. |
looks good :thumb: |
That's really good. The best thing is that you did the half-shaft mod. It'll really increase part throttle airflow. Now the air wont have to jump the "speed bump" going past the throttle blade. Nice job. :thumb: I wish I knew what Shaner uses to fill the holes. My S-3 came polished inside and the holes were filled, he also used brass tubes set into the epoxy. Shaner has the best stock modified tb's in my book. :judge: |
how do you do the half-shaft mod, i've always wondered about that when i see ported TBs without that part of the shaft.....just never thought to ask until now..... |
Originally Posted by slpss9723 how do you do the half-shaft mod, i've always wondered about that when i see ported TBs without that part of the shaft.....just never thought to ask until now..... |
Just use a hammer to knock it out. Hit it on the side where the TPS goes (TPS removed of course lol). A washer will come out so dont lose it, its a pain in the a@@ to put the washer back on to but its possible. After you get the shaft out its much easier to work with too. |
Originally Posted by Shurtz8 Just use a hammer to knock it out. Hit it on the side where the TPS goes (TPS removed of course lol). A washer will come out so dont lose it, its a pain in the a@@ to put the washer back on to but its possible. After you get the shaft out its much easier to work with too. |
1 Attachment(s)
Originally Posted by FIREHAWK#608 My S-3 came polished inside and the holes were filled, he also used brass tubes set into the epoxy. Shaner has the best stock modified tb's in my book. :judge: Anyway good job on the do-it yourself :cheers: |
Is the half shaft mod worth it on these style motors? i did it on my old car kinda helped. |
Nice job, it looks good. |
that looks bad ass man, very nice. home ported tb's are much cheaper and i like doing my own because you can do it how you want. very easy to do. |
tb looks great. you did a good job. |
what are these mods you speak of half shaft and bump stop etc what do they do?Does this fix the problem when you hit a bump and they car acts funny ? Also what is the benefit to porting the TB ? IS there a write up on how to do these mods ... porting the TB half shaft ET? Thank you ! |
Originally Posted by minesfaster what are these mods you speak of half shaft and bump stop etc what do they do?Does this fix the problem when you hit a bump and they car acts funny ? Also what is the benefit to porting the TB ? IS there a write up on how to do these mods ... porting the TB half shaft ET? Thank you ! |
Is there a write up on how to do this ? |
i'd like to know as well. |
Id like to see a write up as well. |
i found this on a search a long time ago.... but i couldnt upload the zip so i just uploaded the site... (only 4.2mb an hour so if it doesnt work try again in an hour...) http://geocities.com/tc3_002/ edit: dont bother clicking on any links as they wont work... |
Pretty sure there is one in jrp's sticky. There another one out there as well...I ll try to dig it up for you guys. |
Originally Posted by tc3 i found this on a search a long time ago.... but i couldnt upload the zip so i just uploaded the site... (only 4.2mb an hour so if it doesnt work try again in an hour...) http://geocities.com/tc3_002/ edit: dont bother clicking on any links as they wont work... I replicated that into a webpage a while back with a few updates: http://www.geocities.com/wilwaxu/throttlebody.html |
| All times are GMT -5. The time now is 09:23 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
