o2 simms throwin ses light
Old 01-04-2006, 07:51 PM
SouthernSilverSpeed's Avatar
Default o2 simms throwin ses light
I just installed my pacesetter LT's and ORY. I bought 2 new rear o2 simms and installed them also. After the install, I got the codes 138 and 158 which are the two rear o2's So I cleared the codes and from what I hear after you clear the codes once then the light shouldn't come back on right? Well I have cleared the codes like 10 times and they keep coming back on , but only at WOT or hard acceleration. If I drive like my grandma then they won't come on.
Any suggestions?
Am I supposed to reset the computer or just clear the codes?
Do I have a pair of bad 02 simms? Remeber they are NEW.
How do you reset the computer?
Any help would be great. Thanks!
Old 01-04-2006, 08:15 PM
02blkws6vert's Avatar
disconnect the negative battery terminal
Old 01-04-2006, 08:55 PM
dschmittie1's Avatar
sounds like you got a bad set of sims happens from time to time send them back if you can it happened to my friend
Old 01-04-2006, 11:25 PM
Thats what I thought
Old 01-05-2006, 06:21 AM
Juiced2000SS's Avatar
I had a bad sim when I put an ORY on my GTP. Couldn't figure it out at first.. Good luck.
