header wrap?
Old Feb 20, 2006 | 06:02 PM
MetallicaMatt's Avatar
Default header wrap?
i'm going to put on a cutout on my exhaust, and instead of welding them all the way around, could i tack it on a few spots (so it'll be easier to take off) and put header wrap around the ends?
would that seal it up?
I've never used the stuff before, looking for some ideas
thanks guys
Old Feb 20, 2006 | 06:07 PM
LS69TA's Avatar
No, the wrap doesn't seal that good. It's made of fibers woven together.
Old Feb 20, 2006 | 06:10 PM
slow trap's Avatar
why will you want to take it back off ?
Old Feb 20, 2006 | 06:26 PM
Starz T/A 17's Avatar
The header wrap wont keep it from heating it is meant to absorb heat so that it keeps underhood temps down. You could always clamp it down I used clamps and never had a problem with it
Old Feb 20, 2006 | 06:39 PM
what clamps?
Old Feb 20, 2006 | 10:50 PM
redbullapril23's Avatar
you could always weld the 3 bolt flange connectors on it....
Old Feb 21, 2006 | 12:18 AM
Originally Posted by MetallicaMatt
what clamps?
I just cut the catback a little bit and put it between the catback and Y pipe and used "U" clamps from advanced auto to hold it. Sure its not the best but it worked
Old Feb 21, 2006 | 05:11 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It is not worth it IMO. Coating would work better.
Old Feb 21, 2006 | 05:28 AM
magius231's Avatar
just throw some band clamps on it. No crimping and you can take it off if you need later.
Old Feb 21, 2006 | 04:17 PM
thanks guys!
