Changing my Differential fluid this week...questions...
Which would be best to use?
Also, I know i need the GM additive, some RTV silicone and a new gasket.
Which gasket should i buy?
I see that it's pretty much straightforward...
Remove cover, clean it all out, reinstall w/ a bead of RTV then the gasket then another bead of RTV, then fill w/ fluid and GM additive...
Anything else i should look for/do?
Thanx alot! <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
-Josh
Moved to drivetrain
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=2;t=002694
<small>[ May 18, 2002, 01:59 PM: Message edited by: WILWAXU ]</small>
