Need help with FLP install
Old Jun 4, 2002 | 08:32 PM
Savageite's Avatar
Default Need help with FLP install
I am almost done putting them on but I'm having trouble getting the EGR vavle back in the hole on the headers on both sides. I think it's the egr vavle anyways. It just won't line up. Should I try to bent it, what should I do. Someone please help me out.
Old Jun 4, 2002 | 08:40 PM
DriveATransAm's Avatar
Default Re: Need help with FLP install
they are the AIR tubes. you need to get pre 00 tubes. you can also bend your, but be sure not to snap them off because they bend easy.
Old Jun 4, 2002 | 11:01 PM
Slowhawk's Avatar
LS1Tech Sponsor
You'll have to do a little bending.Disconnect them from the rubber hoses and trial bend them a little at a time till they are close.You might have to drill out the holes a little bigger on the valves to line up the bolts.If these are new FLP's for your year car.The air tubes will be right..
Old Jun 5, 2002 | 04:26 PM
Savageite's Avatar
They are new and they are supposed to be for my car. 02 Z28. I geuss they gave me the wrong ones. Thats just great I just spent $1300 and I got the wrong ones.
