people with Hooker LT's, question
Old Mar 13, 2006 | 05:39 AM
magius231's Avatar
Default people with Hooker LT's, question
I just installed my Hooker LT's this weekend, and one problem I am having is the drivers side O2 sensor is pretty much right up against the fuel line heat shield. I banged the shield in a litle, but that makes me nervous since it could be rubbing the fuel lines now...how did you guys solve this problem?
Old Mar 13, 2006 | 08:06 AM
Blacker's Avatar
I ended up cutting away some of the shield and had no problems with clearance.
Old Mar 13, 2006 | 11:18 PM
MOTRUBL's Avatar
I plan on welding a new bung on the inside part of the header and putting a plug in the outside bung. I had to bend some of the line and stuff to clear for now.
Old Mar 14, 2006 | 12:19 AM
jerflash's Avatar
easy fix...bend the heatshield with some pliars...very easy
Old Mar 14, 2006 | 12:37 AM
cowboysfan's Avatar
buddy installed same headers on his 01 T.A. he had same problem. he as well performed some mod's like previous replies here. guess it's normal w/ hooker headers.
fuerzaws6
Old Mar 14, 2006 | 05:09 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I cut the heat shield out. Just a notch. never worked better. Just don't cut your self if you ever have to take it out.
Old Mar 14, 2006 | 07:00 AM
magius231's Avatar
ok thanks guys, glad I'm not the only one
